How to record a sound file from the radio
- Re: How to record a sound file from the radio
10-07-2012 9:49 PM
I don`t want to record music, and only need a max of 2 minutes.
I need the sound file to send to a contact in the U.S. via email.
I have a double ended jack lead to connect the REC from the radio to the MIC on the laptop.
10-07-2012 10:30 PM
I would have thought that would make short work of recording a audio sample from the microphone or line input.
10-07-2012 10:40 PM
10-07-2012 10:41 PM
10-07-2012 10:45 PM
Google is your friend.
10-07-2012 10:47 PM
10-07-2012 10:52 PM
will go away and check out the linkys ......
10-07-2012 10:55 PM
much appreciated.
10-07-2012 10:57 PM
10-07-2012 11:43 PM
11-07-2012 1:40 AM
11-07-2012 8:25 AM
I think Audacity, will be a bit OTT for my application , ! ! ..
actually, tried to record some sounds last night with the windows sound recorder, although the cursor moved along as if recording there was no sound on the windows or Irfanview player...
( I know the link cable is good because I use it for other radio/computer applications )
11-07-2012 11:56 AM
Quote from: shutter I have a double ended jack lead to connect the REC from the radio to the MIC on the laptop.
If it is a radio station with a streamed internet option then the alternative is to capture the section of the stream that you want. I would have thought that would achieve better sound quality.
11-07-2012 1:33 PM
Quote from: shutter actually, tried to record some sounds last night with the windows sound recorder, although the cursor moved along as if recording there was no sound on the windows or Irfanview player...
The microphone input on your laptop may need enabling in Control Panel / Sound / Recording tab where you should also be able to see it in action on a bar-graph.
11-07-2012 2:02 PM
@Strat.... the mic socket is already enabled, as I mentioned in my brackets previously ! ( I know the link cable is good because I use it for other radio/computer applications ) well, not specifically, but the inference is there ! ! ! ...
