How to... record LIVE TV stream on laptop
FIXED- Subscribe to RSS Feed
- How to... record LIVE TV stream on laptop
- « Previous
- 1
- 2
- Next »
Re: How to... record LIVE TV stream on laptop
28-12-2017 11:44 AM
Don't watch TV that much anyway, and never on the PC.
As for installing loads of files in a folder, luckily on Linux all you have to do is delete the folder not like M$ where the registry is so bloated it needs cleaning then falls over.
28-12-2017 12:58 PM - edited 28-12-2017 1:04 PM
Very true.
A TV screen will give better quality video than any PC.
But I tend to download programmes to my PC & use it as a media player.
My TV will play video files via DLNA.
So I generally get limited to iPlayer - but I'd like to have access to the Channel 4 catch-up programmes.
BTW it only takes 10 minutes to set up a VM and it's an excellent way of testing non-repository software.
28-12-2017 4:52 PM
Finally!!!
Just found out how to do it properly (in Linux) to give what appears to be SD quality.
vokoscreen is a screen capture program which gives a H264/AAC format in a MKV file.
AFAIK it didn't drop any frames in 45 minutes of a full-screen capture.
29-12-2017 9:44 AM
08-01-2018 11:35 AM
Most (but not all) TV catch-up services stream the content, which means you are beholden to them.
Since my TV doesn't do flash, I require a download.
This gives two choices - torrents or screen capture off of my PC.
- « Previous
- 1
- 2
- Next »
