How to install software without serial no
newinvention
As per my last post about my printer problems, the other software that the PC upgrade affected was Macromedia Fireworks. I had an old but perfectly viable version of this running on my PC, but it was corrupted (or something) by the upgrade so I was told to uninstall/reinstall. OK, did uninstall. Started reinstall then get a message that I need the serial number (it's more like a password) to get to the programme! But I can't find that number anywhere. It was on a postcard in the software box, but I can't find the bloomin' card!! So I'm stuck. Is there any way of bypassing this part of the installation or is it illegal to ask such things! The programme is Fireworks 2 - dont' laugh!! I need it urgently. Thanks anyone.
Re: How to install software without serial no
You have a private message  Wink
newinvention
Doh - thank you! Have pm'd you back.  Grin
