How to do a cosmetic repair to my keyboard
Oldjim
Resting Legend
Fixes: 63
The keys on my keyboard (white letters on black) need a bit of tender loving care as part of the white letters has worn off.
As my touch typing skills are sadly lacking I would like to - carefully - repaint them.
Other than needing to borrow (steal actually) a very thin brush from SWMBO who is an artist are there any other suggestions
One thought is to use a white CD marker pen (very fine)
16 REPLIES 16
Strat
Fixes: 565
Re: How to do a cosmetic repair to my keyboard
Correction fluid would be good Smiley
...and you probably have quite a good stock of it Wink
VileReynard
Fixes: 20
My 'N' has completely disappeared and the right hand side of the 'M' is nearly gone..  Cheesy
hulls
Not surprisingly - the "E" has completely gone on my keyboard.  ( the letter used most in the English language)  Roll_eyes
Oldjim
Resting Legend
Fixes: 63
Quote from: Strat
Cheeky sod  Shocked
Beside that rubs off  Roll_eyes
HairyMcbiker
All Star
Fixes: 21
Jeez you must have poor keyboards!
I use a M$ Ergonomic Internet keyboard and have done for about 5 years (this one) and NONE of the keys are worn! Even my old IBM thinkpad which had a hard life still has very little wear on it.
While I fully support repairing most things to get them back to a working condition, I doubt that painting new letters on a keyboard is going to last very long.
If it were me, I would consider buying a decent keyboard of eBay, as you can get a good quality, brand new, branded keyboard (such as Microsoft) for less than £5.
Another even cheaper option that might work is to use a label making machine to make some permanent letter labels to stick over the old key caps.
Oldjim
Resting Legend
Fixes: 63
VileReynard
Fixes: 20
Do IBM still make keyboards?
ChemicalBrother
David_W
You could find another black keyboard (preferably broke) and take the keys from that, simply replace them.  If you use any sort of marker on the keyboard then you using the keys will in turn rub off whatever you mark it with.  My current (and future, hopefully a long time) keyboard is a logitech g15, the keys are laser etched with a pretty orange backlight so can never wear off so if you can find a broken G15, rip the keys from one of them, though they may not fit, umm, only thing I really can think of is to replace the keys with keys from another keyboard.
jelv
Fixes: 10
If you'd got a proper keyboard in the first place (one where the keys are double shot molded - Google it) you wouldn't be having this problem!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ReedRichards
Seasoned Pro
Fixes: 25
I have a silver 'paint marker' pen, under £2 from Staples, that writes on plastic.  But whatever you use, the problem would be rubbing it off again.  I think some people have "acid fingers" and are more than usually prone to rubbing of the lettering on their keyboard.
orbrey
Letraset and clear lacquer?
White enamel paint?
Very carefully cut stencils and spray paint?
Any of the above should give a lasting finish but it's a lot of work, iirc you can pick up those logitech boards for between £5 and £10 these days. Alternatively you could wear all the labels off and go for the uber-leet Das Keyboard look.
pierre_pierre
I use a clear melamine lacquer on my wood turning, it is heat and acid proof, mind you a tin of it costs more than a new keyboard Roll_eyes Roll_eyes
