How to Start
- How to Start
How to Start
23-09-2009 7:11 AM
Would appreciate tips on where to start just to assess whether I am capable of it. Is it very difficult to do?
Being September, am wondering if I ought to telephone the local college to see if they have any courses.
I would rather have one to one tuition though so don't mind paying for this if it is not too expensive.
Re: How to Start
23-09-2009 8:28 AM
http://www.w3schools.com/default.asp
They certainly helped me to break free from M$ Frontpage and start to do some "real" website building
Cliff
Re: How to Start
23-09-2009 8:51 AM
You could do worse than by just installing SMF to give you a good base point.
http://www.simplemachines.org/
Appreciate that doesn't help with your website but I'm rubbish when it comes to design
I have a friend that sorted out mine for me
Re: How to Start
23-09-2009 8:52 AM
http://www.wix.com/
which has about 90 "templates" that you can "edit"....
Not used it, but it says it is FREE and EASY to use..... looks like there`s plenty of choices, so you may like to play around with a couple to see how you much interest you need to get your website
Re: How to Start
23-09-2009 9:25 AM
Also googled web design for South Yorkshire and there are lots of choices but they are all about doing the website for you and I want someone to do the work with me so that I can learn and maintain it. As it is going to be a forum it is important that I understand the nuts and bolts of the thing.
The more I think about it the more I realize that I am going to need professional help so that will mean raiding the bank account I suppose.
James - is your pal in South Yorkshire and does he do it for a living? Also, what is your website?
Re: How to Start
23-09-2009 9:32 AM
He's my house mate The main part of his job is in web design.
Mines @ http://unlikely-perfection.co.uk
Re: How to Start
23-09-2009 9:46 AM
Have just telephoned a couple of numbers obtained from Google. I think that because it is a forum I am going to have to let someone else do it and get them to teach me how to maintain it.
There is a slim possibility that I might get help with funding if I ask around.
Re: How to Start
23-09-2009 10:02 AM
My website is just a customised version of Wordpress, which shouldn't be too complicated.
Re: How to Start
23-09-2009 10:46 AM
Have contacted one or two people who I know and might be interested so they might be able to help with advice and/or funding - will wait and see. Don't suppose that Plusnet have a sponsorship budget? As my idea is related to dogs, I suppose not.
In retrospect, I think that I was a bit naive to think that I could do it myself, but am grateful for all replies so far - they have helped to clarify my thoughts.
Re: How to Start
23-09-2009 11:04 AM
I've replied to your PM.
Re: How to Start
23-09-2009 1:04 PM
If you want to do something fairly simple then check out local authority adult education courses. You will have to pay something for it but if you can find a local course it should teach you a lot about how to build a basic site.
Re: How to Start
23-09-2009 5:27 PM
Re: How to Start
23-09-2009 7:16 PM
Your breakdown of the skills needed is interesting. My input will have to be maintaining it so I hope that I am equal to the job.
Pierre - thanks for the link. Going to check it out. Had thought of using Plusnet but don't know the ins and outs of it all as I don't use the webspace that comes with my own domain.
Since posting I have had the thumbs up from the webmistress of one of the associated organisations (this had been discussed before at their meetings) so I am rather hoping that they might be able to help me with a bit of funding as I understand that it can be a bit costly to maintain over the year.
My 'mentor' so to speak quotes a figure of about £200 pa for her forum which she pays for herself.
Re: How to Start
23-09-2009 8:46 PM
As Jameseh said for a forum you could use SMF like this one or phpbb, either of which installs itself with a few options. Also loads of free templates and help available.
Re: How to Start
24-09-2009 1:22 PM
Thank you for all help and advice.
