How to Reinstall Windows Without Having to Reactivate
Steve
Seasoned Pro
Every time you format and reinstall your PC, you have to activate Windows again, which can sometimes be a pain once you’ve done it too many times. Here’s how to backup and then restore the activation status.
Advanced Token Manager easily allows you to back up all the information that Windows uses to check the validity of you copy of Windows. Collectively called a Token, this information can be backed up to an external storage medium. Once you have formatted you can import the Token and your Windows will be genuine again.
Advanced Tokens Manager
If life gives you lemons, make lemonade.
Re: How to Reinstall Windows Without Having to Reactivate
Have you tested this?
Call me 'w23'
Steve
Seasoned Pro
Yes and It works well, And saves a lot of hastle and time.
Thanks.
Call me 'w23'
