How to Calibrate your TV to get the best possible Display
- How to Calibrate your TV to get the best possible ...
15-10-2014 5:00 PM
http://www.techradar.com/us/news/television/tv-setup-guide-14-tips-for-getting-the-best-picture-qual...
Re: How to Calibrate your TV to get the best possible Display
15-10-2014 5:21 PM
Posting a link bait title and then linking to that article.
Its very basic advice that will give you a better than out the box experience at best. It will not give 'the best display possible'
15-10-2014 5:31 PM
I will go over the settings again when I have more time with the manual in hand.
Forum Moderator and Customer
15-10-2014 5:35 PM
It's not the display I have problems with it's the sound, pity they don't give advice about that other than to buy a soundbar.
Quote from: DaveyH You really have been spending to much time on the DM website.
15-10-2014 5:38 PM
15-10-2014 6:34 PM
http://www.avsforum.com/forum/139-display-calibration/948496-avs-hd-709-blu-ray-mp4-calibration.html
It will give better results than TRs advice (though ideally you need blue filters or 'THX' glasses for best results)
Or you could go the whole hog and get something like a Spyder 4 and use the HCFR software, which will give the best results possible outside of getting a pro calibration
15-10-2014 6:58 PM
For domestic use some basic guidance is all that is needed. I would hazard a guess that most users wouldn't necessarily notice any marked difference anyway.
15-10-2014 7:16 PM
Quote from: Mav Or you could just play around with the settings till you are happy with what you see
You could but that misses the point, and you may as not bother
Quote For domestic use some basic guidance is all that is needed. I would hazard a guess that most users wouldn't necessarily notice any marked difference anyway.
They will, and they probably won't like the look of the picture either at least initially, especially if they've been running in and got used to the'Dynamic' modes with contrast, brightness cranked up and all the garbage picture processing/enhancements enabled
15-10-2014 7:24 PM
Not everyone would share their eyesight
What looks sharp / vibrant etc to them, wont be seen exactly the same by everybody
15-10-2014 7:38 PM
The One Show started to look dull and lifeless so I put it back to default.
15-10-2014 7:44 PM
Quote from: Strat
I thank you
15-10-2014 7:49 PM
Quote from: Strat
Always did look like that..... and I never adjusted anything....... except the channel number when it comes on
16-10-2014 3:48 AM
Nothing to do with the DM !!!
RSS Feed indicated the Article !!
See screen Grab below ....
Quote from: PlusComUK Many useful tips here for the domestic user.
Quote from: DaveyH
I was keeping it simple !!
My basic advice has always been to adjust your TV to give the best possible B&W picture, than add Colour, not too much..
Remember PLUGE !!
Quote from: DaveyH I would recommend downloading the test patterns/manual and following the basic instructions from it at
I have that site in my Bookmarks.
Here's another one, designed for Computer Monitors setup.
http://www.displaycalibration.com/
RSS grab below
16-10-2014 3:07 PM
Claims my 24" monitor is better than perfect.
16-10-2014 3:12 PM
Quote It's not the display I have problems with it's the sound, pity they don't give advice about that other than to buy a soundbar.
Agreed. Everything had different sound levels. Poking around in TV set up though - Panasonic - found an option - Equalise sound input over channels. Very impressed, can switch between tv, freesat box, dvs player without having to reach for remotes.
Might be worth a look to see if your tv has something similar.
