How to Calibrate your TV to get the best possible Display
15 REPLIES 15
DaveyH
Champion
Fixes: 12
Re: How to Calibrate your TV to get the best possible Display
You really have been spending to much time on the DM website.
Posting a link bait title and then linking to that article.  Wink
Its very basic advice that will give you a better than out the box experience at best. It will not give 'the best display possible'
Mav
Fixes: 515
It did prompt me to check what settings I had and make some improvements including turning off Overscan.
I will go over the settings again when I have more time with the manual in hand.
Forum Moderator and Customer
gleneagles
Aspiring Legend
Fixes: 17
Quote from: DaveyH
It's not the display I have problems with it's the sound, pity they don't give advice about that other than to buy a soundbar.
We are born into history and history is born into us.
TORPC
I darn't attempt to check the settings here ATM as I would end up having an interesting discussion with more than one female & as I am the only male here, I would be outvoted in less than a millisecond Tongue
DaveyH
Champion
Fixes: 12
I would recommend downloading the test patterns/manual and following the basic instructions from it at
http://www.avsforum.com/forum/139-display-calibration/948496-avs-hd-709-blu-ray-mp4-calibration.html
It will give better results than TRs advice (though ideally you need blue filters or 'THX' glasses for best results)
Or you could go the whole hog and get something like a Spyder 4 and use the HCFR software, which will give the best results possible outside of getting a pro calibration
Mav
Fixes: 515
Or you could just play around with the settings till you are happy with what you see Wink
For domestic use some basic guidance is all that is needed. I would hazard a guess that most users wouldn't necessarily notice any marked difference anyway.
DaveyH
Champion
Fixes: 12
Quote from: Mav
You could but that misses the point, and you may as not bother  Smiley
They will, and they probably won't like the look of the picture either at least initially, especially if they've been running in and got used to the'Dynamic' modes with contrast, brightness cranked up and all the garbage picture processing/enhancements enabled
TORPC
Have they taken into consideration that,
Not everyone would share their eyesight
What looks sharp / vibrant etc to them, wont be seen exactly the same by everybody
Strat
Fixes: 565
I ran through the procedure on my LED backlit TV just now.
The One Show started to look dull and lifeless so I put it back to default.
DaveyH
Champion
Fixes: 12
Quote from: Strat
I thank you Wink
shutter
Fixes: 65
Quote from: Strat
Always did look like that..... and I never adjusted anything....... except the channel number when it comes on  Grin Grin
Quote from: DaveyH
Nothing to do with the DM !!!
RSS Feed indicated the Article !!
See screen Grab below ....
Quote from: PlusComUK
Many useful tips here for the domestic user.
http://www.techradar.com/us/news/television/tv-setup-guide-14-tips-for-getting-the-best-picture-qual...
Quote from: DaveyH
I was keeping it simple !!
My basic advice has always been to adjust your TV to give the best possible B&W picture, than add Colour, not too much..
Remember PLUGE !!
Quote from: DaveyH
I have that site in my Bookmarks.
Here's another one, designed for Computer Monitors setup.
http://www.displaycalibration.com/
RSS grab below
VileReynard
Fixes: 20
I tried that on my computer monitor.
Claims my 24" monitor is better than perfect.
BruceMcTavish
Agreed. Everything had different sound levels. Poking around in TV set up though - Panasonic - found an option - Equalise sound input over channels. Very impressed, can switch between tv, freesat box, dvs player without having to reach for remotes.
Might be worth a look to see if your tv has something similar.
