How long until fibre enabled?
Protech
Seasoned Pro
Fixes: 8
The following cbt? boxes have appeared on the poles in our street.
I've checked the BT wholesale broadband checker and fibre is not showing as available yet.
How long is it after these installations that fibre usually becomes available, weeks or months? IMG_20230907_173026.jpg
You can check out but you can never leave ( easily)
4 REPLIES 4
Re: How long until fibre enabled?
@Protech
Look at the CBT closely I see a Virgin Media badge, are you sure it's been put there by Openreach?
RealAleMadrid
Fixes: 68
@Protech  It's Virgin Full Fibre and it seems to be fitted at a jaunty angle.😁
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Tech Help
Protech
Seasoned Pro
Fixes: 8
@Dan_the_Van
Well spotted 👏, I've checked the virgin media broadband checker and that's also showing as unavailable.
Guess I'll just have to wait for the mailshots announcing availability
