How good is Miray's HD Shredder Programme?
chandu
I shall appreciate any input on the above software.  How good and reliable is it?  Any one tried it?  If so, your feedback will be very helpful.
Many thanks.
Razer
Re: How good is Miray's HD Shredder Programme?
For free space wiping, I use either CCleaner or Recuva. For file erasure, I use Eraser 5.8. All free programs. That said, none of them can erase two particular 'deleted' files from my hard drive. I'd be interested to know if this program could.
chandu
I have down loaded it but haven't got round using it on an old pc.  When I do,  will post the results here.
Chandu.
