How fast would a link between a switch and a router connected device be
- How fast would a link between a switch and a route...
- « Previous
- 1
- 2
- Next »
Re: How fast would a link between a switch and a router connected device be
05-06-2015 11:25 PM
Gb switches can handle Jumbo frames - which could help your throughput.
05-06-2015 11:37 PM
Quote from: nanotm yes I did mean 100Mb on the wan port and 1Gb on the lan side of the switch.... although some were described the other way round ....
If you have a WAN and LAN, then you have two difference network addresses with routing, otherwise it is an uplink. I would be very surprised if the uplink was slower than the LAN as it defeats the object of a dedicated uplink.
Older devices have an uplink because they do not support automatic switching between MDI and MDI-X and the uplink is common with one of the LAN ports. Modern (consumer) devices with an uplink port tend to have a 10x uplink.
I get the impression yours is an oldish device which doesn't have the "store and forward" buffering that is needed for mis-matched speeds to run effectively.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
- « Previous
- 1
- 2
- Next »
