How do I reduce Windows 10 phoning home?
- How do I reduce Windows 10 phoning home?
04-01-2016 3:43 PM
It is a Windows 10 replacement for Windows 7.
Does anyone know of a link to some instructions on what to do to gain a little privacy?
(Other than loading Linux of course!).
Re: How do I reduce Windows 10 phoning home?
04-01-2016 3:53 PM
2. purchase a similar size new HDD
3. Install the new HDD
3a. if necessary purchase a copy of Windows 7 professional
4. Install Windows 7 professional.
5. Start to install all the updates, ( leave it overnight)
6. make sure you DO NOT install KB 3035583 ( Win 10 update nag)
7. install all other useful programs
8. copy files and folders from old machine ( using Linux and a caddy if necessary).
9. install files and folders copied from old machine.
10 Good Luck.
04-01-2016 4:01 PM
04-01-2016 4:28 PM
Change your Windows 10 SETTINGS NOW!
The 52 hidden settings you must switch (because Microsoft's defaults are not safe)
York.
04-01-2016 4:32 PM
@shutter - I'm very keen to offer M$ as much money as possible.
But your method would probably fail since the new disk is 1TB and the old one is 500GB.
Not to mention that I would have to muck about with secure boot in the EFI BIOS.
@NedLudd - do I have to pay money for that magazine?
04-01-2016 4:40 PM
York.
04-01-2016 5:11 PM
http://www.blackviper.com/service-configurations/
04-01-2016 5:24 PM
Quote from: vilefox Thanks @Spoon Whittler - I'd seen that about Microsoft logins.
Erm... no ... you don`t have to muck about with secure boot..... cos you are installing a NEW hard drive.... of whatever size you decide your daughter will need,... even 1tb.. !... and then .. if you had read my instructions, carefully numbered, so you would not get lost... you would be installing a FRESH copy of WIN 7 Professional.. which does not have " secure boot"...
04-01-2016 5:50 PM
04-01-2016 7:16 PM
https://fix10.isleaked.com/
https://4sysops.com/archives/install-windows-10-with-a-local-account/
http://www.top-password.com/blog/turn-on-or-off-fast-startup-missing-in-windows-10/
and this one to fix common errors
http://home.bt.com/tech-gadgets/computing/has-your-windows-10-start-menu-stopped-working-here-are-fo...
04-01-2016 7:50 PM
04-01-2016 11:46 PM
Had to remove some rubbish - antivirus, Office and install a couple of browsers.
Big lack of any performance monitoring tools and install/rebooting is incredibly slow.
05-01-2016 4:10 AM
https://github.com/WindowsLies/BlockWindows
Also useful for keeping those telemetry updates away from your Windows 7 and 8{.1] machines.
05-01-2016 11:08 AM
05-01-2016 3:01 PM
I can see why people pay good money for SSD's just to get decent response times.
A new Windows 10 is taking one minute to power up and sign on to a single user.
It also takes about 45 seconds to shut down!!!
BTW I'm so impressed by security on Windows 10 that I'm booting into a single user as Admin without a password.
Just like everyone did with XP.
I'm strongly unimpressed with Windows 10.
