How do I go about replacing my Plusnet techinicolor router?
- How do I go about replacing my Plusnet techinicolo...
05-08-2015 8:24 PM
I'd like to upgrade my plusnet technicolor router to newer, better hardware.
I've two questions regarding this,
Which router should I buy on a budget (<£20 inc p+p, fine to buy used)
How complicated is setting up a new router not from the provider? I've only ever used routers given to me by plusnet and past internet providers which I think had everything pre programmed?
Very grateful for any answers/suggestions
A.Z.
P.S. I'm contracted to plusnet (ADSL) if that makes any difference
A.Z.
3 REPLIES 3
Re: How do I go about replacing my Plusnet techinicolor router?
07-08-2015 11:57 AM
if your budget is less than £20 then it's unlikely you'll get one that is any better than the plusnet supplied router.
if you did get another router than all you need is your plusnet username and password.
07-08-2015 4:43 PM
Thanks, good to know it isn't hard to set up.
Time to hunt for a deal
07-08-2015 5:45 PM
Try this.... for starters....... Don`t ask me which is bestest ! ! ...
http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_sop=15&_nkw=adsl+router&rt=nc&LH_BIN=1
