How do I get rid of .......
Fixes: 16
I have downloaded/installed "Damnvid" on the Linux MINT 11 Laptop.... but it doesn`t suit my needs, so I now want to "get rid"....
How do I get rid? and clear the installation from the HDD ?
VileReynard
Seasoned Pro
Fixes: 10
Re: How do I get rid of .......
How did you install/download "damnvid" - was it via a package manager?
Fixes: 16
Not exactly sure.... first "try" was via a "terminal" script  from  a website... (can`t find it now !! !)... but did not find it after all the scripts finished, so I think I downloaded it again from www.giveawayof theday.com
Then had a problem actually finding it in the Applications list... but did eventually find the icon and put that on my desktop
VileReynard
Seasoned Pro
Fixes: 10
This looks like some Windows siteHuh?
You downloaded some untrusted software (and) presumably installed it with a script.
This is basically why Windows ends up with a load of random c**p.
If you right click the icon on your desktop(?) and click on properties what do you see?
Is it anything like
Fixes: 16
No... it looks "linuxy" ... Undecided and has Command /usr/bin/damnvid as one of the boxes on there (with 281bytes & desktop configuration file)
Fixes: 20
Ok on the web page it is listed as a todo on how to uninstall in Linux  Crazy
Web page is here (https://code.google.com/p/damnvid/wiki/Help)
@Shutter did you use the ppa to install it? If you did you should be able to do
apt remove damnvid
to remove it then remove the ppa using synaptic.
Fixes: 16
Ok thanks HB.... point of interest.... I am at the seafront with my Linux laptop, and took 2 mins to get on line from boot up with instant connection from my 3 Mobile Dongle...  Smiley  Brill..... my Windows hdd took about 10 mins to boot up and then I had to wait for another 5 mins for the dongle to connect !
will check out your linky when I get home..
VileReynard
Seasoned Pro
Fixes: 10
If you installed it via some script which deleted itself, then you are going to have to track down each and every component if you want to fully delete it.
Or you can run two programs:-
sudo /usr/bin/updatedb.mlocate
(and enter your password)
This will take several minutes to run the first time you run it - it builds a compressed list of all the filenames on your PC.
Then type
locate string
where string is a sequence of characters such as damnvid etc
All files or directories which contain that string will be listed.
You can selectively delete the files....  Grin
I bet you will be left with a lot of disconnected rubbish though.
I auto-run that first command on a daily basis (it is much faster after the first run).
Fixes: 16
Quote from: Hairy
apt remove damnvid
Thanks very much HB.... did the "apt remove damnvid" and it has been done... (had to do an "autoremove" after to remove some "python" files...
Job Done  Wink
@ fox..... always handy to have an alternative..... thanks. Smiley
VileReynard
Seasoned Pro
Fixes: 10
Lucky you used a package!
Fixes: 16
Yay... Wonder if I should do the Lottery tonite  Roll eyes
Fixes: 20
Quote from: shutter
Gawd 2WHOLE min to boot and get on-line you need a faster disk!  Cheesy
Glad you have got rid of it, but from now on please only install from ppa's or the repository so that you can remove using Synaptic easily.
