How do I connect this to the mains
Oldjim
Resting Legend
Fixes: 63
Re: How do I connect this to the mains
Slight hiccough
Decided on the unit we wanted but as a final check looked at the installation diagram
Who would have thought it - the unit depth is deeper than normal by about 2" so it won't fit in my 560 deep unit - needs a 600 deep unit
Just goes to show - assuming that modern oven units would use the same cabinets was a mistake and could have been a very expensive one
pwatson
Out with the chisel then  Cheesy
Best of luck with hunting for the right oven - You never know it might be less than 3kW Wink
Oldjim
Resting Legend
Fixes: 63
It will be either a Neff or a Bosch but checking with a Neff dealer the one I was considering is being replaced with a new model this month
Not yet on the UK website but is on the Belgium one and doesn't look too bad so another slight delay - fortunately the present Neff unit is still working albeit with a rather noisy fan and no internal lights
Note that replacement cost for a Neff fan/motor unit plus lights including fitting is topside of £200 and probably nearer £250 which is why I am going for a new one
twocvbloke
That's one of the things I hate about manufacturers today, build something for pennies, sell for top dollar, and charge extorionate prices for replacement parts making it uneconomical to maintain and repair... Roll_eyes
It's why I like old hardware, easy to fix, plentiful affordable spares, and keeps things out of the dump... Smiley
PeterLoftus
Fixes: 5
Quote from: twocvbloke
Try telling that to SWMBO new kitchen is required so perfectly good eye level oven, dishwasher and fridge all fitted are all due to be trashed  Grin
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Oldjim
Resting Legend
Fixes: 63
The new Neff has - wait for it - a Sabbath feature
http://en.wikipedia.org/wiki/Sabbath_mode
twocvbloke
Quote from: PeterLoftus
Stick it all on ebay, someone's more appreciative SWMBO would probably love to have them at knockdown prices... Grin
w23
Fixes: 4
Or Freecycle if you're more 'community spirited'  Wink
@Oldjim, you can make anything fit if you have a big enough hammer.
Call me 'w23'
Strat
Fixes: 565
Oldjim's an engineer so a big hammer is the only tool in his box.
Oldjim
Resting Legend
Fixes: 63
There is a problem
The plaster is bonded directly to the wall (about 16mm thick and) - I have never heard of this before - the plaster is rock hard to the extent that when I needed to chase out a channel for the 30 amp feed to the cooker point I had to use a cutting disc as using a normal bolster it just bounced off.
You can imagine the mess that made in the kitchen
To correct strat - I also have a really big adjustable spanner
PeterLoftus
Fixes: 5
I wouldn't be without a pair of mole grips lol  Wink
w23
Fixes: 4
No, not the dreaded 'Mole-wretch', be far the most efficient way to mis-shape any nut or bolt-head such that it can only possibly be undone using a ...
Mole-wretch.
Luckily I broke the jaws of my 'self-gripping plier wrench' years ago trying to undo a particularly stubborn bolt.
Call me 'w23'
PeterLoftus
Fixes: 5
Well  there you go  Tongue
Any "engineer" would tell you that mole grips or stilsons for that matter are not for gripping bolt heads but shafts or flat plates  Smiley
w23
Fixes: 4
Exactly why Mole Grips should not be sold to the young and inexperienced.
@Oldjim, have you tried something like this type of thing: https://www.google.co.uk/search?q=sonic+cutting+tool&ie=utf-8&oe=utf-8&rls=Palemoon:en-US&client=pal... ?  I'm sure they'll tackle most materials (with the correct blade) and, whilst still creating a fair bit of dust, a whole lot less messy than a cutting disc.
Call me 'w23'
Oldjim
Resting Legend
Fixes: 63
I haven't but it looks extremely interesting but from the reviews it isn't really suitable for a cutting through really hard mortar
Having said that I can see many uses for it where light precision cutting is wanted
