How do I change........picture download folder destination
shutter
Fixes: 65
For the past couple of years...... whenever I downloaded pics from my camera, they have always been sent to c:/Gerry/digital camera downloads 2010....
until today.... when they went to  c:/Gerry/pictures    which is the Windows "default" destination....
when I plug in the camera..... a small box appears bottom left of screen, and shows the pics downloading, and a progress bar..... unfortunately, it does not have any "control" toolbar, so it just does what it does, then disappears, ......
how can I change the destination?
I am using Windows Vista Home Premium.....
2 REPLIES 2
Steve
Seasoned Pro
Re: How do I change........picture download folder destination
Right-click the Pictures icon in the Start menu, and choose Properties. Select the "Location" tab.
If life gives you lemons, make lemonade.
shutter
Fixes: 65
Thanks Steve....
Wink
easy when you know how !.  Cheesy
