How can I limit internet acess at certain times of the day?
jfk
Sorry - new to the forum and you've probably been asked the same question 1000000 times.
I want to limit internet access at certain times of the day to focus my son's mind away from his X-Box and onto his studies. Can someone please help me to do this? I'm not bothered if all internet access is lost for the time or if it is just X-Box access to the net.
Thanks.....jfk  Crazy
2 REPLIES 2
shutter
Fixes: 65
Re: How can I limit internet acess at certain times of the day?
Unplug the router and keep it with you!...  Wink
keep the xbox in a locked cupboard. until you want to let him have it !.  Wink
spraxyt
Resting Legend
Fixes: 75
Some sort of parental control software is probably needed for that, but for your purposes it would have to be on the router to avoid the restriction being bypassed. I don't think the Thomson TG585v7 has time-based parental control but potentially could be manually set to allow connection only to one website when you want to restrict access; the settings would have to be manually changed to open it up when appropriate. Not ideal but a start.
David
