How can I have two files with the same name - SOLVED there was an extra space
Oldjim
Fixes: 63
This isn't a problem but I am puzzled
I run regular backups on my better half's XP machine using Acronis boot CD and the last one - this morning - I told it to use an existing file name by accident but not to use incremental backup
After it had completed and I rebooted into Windows I found that there were two files with the same name but with different creation dates one month apart
I will run another fresh backup just in case but I wondered how it is possible
4 REPLIES 4
HairyMcbiker
All Star
Fixes: 21
Re: How can I have two files with the same name
Not normally possible in windows. You sure there isn't a space or a different letter in there?
I can have several combo's using uPper and Lower case but M$ ntfs/fat isn't case sensitive.
Oldjim
Fixes: 63
I don't think so
However as the file wasn't created under Windows there may have been something in the attributes which differentiated it
jelv
Fixes: 10
Have you got Windows Explorer set to show the extensions?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Fixes: 63
yes and they both had the .tib extension
Ignore - I just realised that there was a space between the end of the file name and the .tib
