How can I have two files with the same name - SOLVED there was an extra space
- Re: How can I have two files with the same name
02-06-2014 10:26 AM
This isn't a problem but I am puzzled
I run regular backups on my better half's XP machine using Acronis boot CD and the last one - this morning - I told it to use an existing file name by accident but not to use incremental backup
After it had completed and I rebooted into Windows I found that there were two files with the same name but with different creation dates one month apart
I will run another fresh backup just in case but I wondered how it is possible
4 REPLIES 4
02-06-2014 10:33 AM
Not normally possible in windows. You sure there isn't a space or a different letter in there?
I can have several combo's using uPper and Lower case but M$ ntfs/fat isn't case sensitive.
02-06-2014 10:46 AM
I don't think so
However as the file wasn't created under Windows there may have been something in the attributes which differentiated it
02-06-2014 10:49 AM
Have you got Windows Explorer set to show the extensions?
02-06-2014 10:49 AM
yes and they both had the .tib extension
Ignore - I just realised that there was a space between the end of the file name and the .tib
