How Do I Access E-Mails From My Former IP?
- How Do I Access E-Mails From My Former IP?
04-09-2007 5:48 PM
I require guidance on how to access my e-mails from my former Tiscali mailbox (dial up) via my Plusnet BB connection.
I use Outlook Express
Re: How Do I Access E-Mails From My Former IP?
04-09-2007 5:50 PM
http://www.tiscali.co.uk/login/index.php?url=/commscentre/email/index.php
04-09-2007 6:08 PM
04-09-2007 6:09 PM
04-09-2007 6:55 PM
I initially used the link which was helpful, then after pottering about, I realised how thick I was being. Oldjim's and James's replies made me check the OE settings. Being absolutely a novice to BB, it did not occur to me to change access via LAN. Now all is well apart from obviously not being able to send e-mails through that account, as was said.
I have a second problem, however. I cannot open any second page on IE7, it simply freezes each time. This is not the case with Firefox. Any thoughts?
04-09-2007 11:01 PM
It is much more reliable and is not full of security holes.
On my other PC (Windows) my IE7 shortcut is in "deleted shortcuts".
04-09-2007 11:08 PM
Basically you can receive mail from any POP3 or IMAP account but (unless you use an authenticated SMTP server) you can only send using the outgoing SMTP server of the ISP you're connected to.
05-09-2007 10:32 AM
05-09-2007 10:51 AM
05-09-2007 11:10 AM
