Hot CPU is hot..
- Hot CPU is hot..
Hot CPU is hot..
08-07-2013 8:17 PM
So I've just ordered one of these: http://www.kustompcs.co.uk/acatalog/info_26027.html
My record temp at the moment is 81 Degrees lol.
What's the highest other people have had?
I'm running an AMD FX-8100 Bulldozer
Hopefully the new CPU Cooler should do the trick....
EDIT: Uploaded attachment of the current idle temp... (Temp1)
Re: Hot CPU is hot..
08-07-2013 8:53 PM
08-07-2013 8:55 PM
08-07-2013 9:00 PM
08-07-2013 9:05 PM
08-07-2013 9:43 PM
your max should be 71 i belive your TBP is 95w so at 81 is a little high, i run BF3 all ultra never go more 51 and is same TDP
08-07-2013 9:44 PM
http://www.scan.co.uk/products/silverstone-sst-he01-heligon-cpu-cooler-6-heat-pipes-and-140mm-silent...
3770K 3.5 clocked to 4.4 @1.200v, 65c playing BF3 with freezer pro 7, now clocked to 4.5 @1.230v 55c with the He01.
08-07-2013 10:15 PM
08-07-2013 10:47 PM
Quote from: purleigh What about baby oil ?
Some of the comments on that link are good.....if one possesses a sense of humour
09-07-2013 9:52 AM
09-07-2013 10:55 AM
Quote from: rongtw Now thats a BEAST of a cooler
I couldn't believe the size of it Ron when I took it out of the box, I didn't think my case would be wide enough. It can take another 2 x 120mm fans, one at the front and one at the back for push, pull, but I bought high profile memory and the front 120mm doesn't clear the memory so I have to have it offset which then makes it stick out of the side of my case so I couldn't get the side panel on.
Thinking of buying a EATX case, maybe a NZXT 530 when they are released next month, then I can fit the other 2 fans and try for 4.6. This weather is no good at the moment though for temps. Inside my case is usually around 20c, and around 23c when gaming but with this heatwave it is getting up to 27c and over 30c when gaming, which is pushing my CPU temps (according to Real Temp) from 55c up to 60c.
I wouldn't mind trying Water cooling at some point, Hairy Biker, I spend nearly as much time in my BIOS than I do gaming, pretty happy with the 4.5 Oc on air though.
09-07-2013 12:06 PM
09-07-2013 1:19 PM
09-07-2013 1:24 PM
Yes it did worry me a fair bit but it was reliable.
09-07-2013 2:58 PM
http://www.overclockers.co.uk/showproduct.php?prodid=CA-130-NX
Looks a bit plasticy but the red will go with my ROG board.
