Host name query
Wimpywoo
Host name query
Hi have just reversed my host name and this information came up, is this correct ? Please could someone explain why it's in a foreign country? Thank you.
3 REPLIES 3
Fixes: 1,482
Re: Host name query
the host name has the ip address reversed so you've traced the wrong one.
it's also not a good idea to post your ip address on a public forum.
Wimpywoo
Re: Host name query
Thank you for your reply , Well I'm getting so many errors inside the router firewall... And when visiting sites and it's getting very annoying I'm getting 503 errors or something like that but thanks for your advice.
Anotherone
Champion
Fixes: 21
Re: Host name query
The way you've posted that, suggests you think the router is to blame for this, would that be so? I doubt that's the case but you need to be specific about the error message - 503 errors or something like that??? All these 50x errors have very specific meanings and will have different causes.
