Homeplugs & Wireless
- Re: Homeplugs & Wireless
27-06-2012 8:42 PM
Installing them was a breeze as in just plug both into the relevant sockets and connect by the supplied Ethernet cables to the router (NetGear DG 834G) and the equipment. All seems fine except that now the wireless from the router seems flaky with the laptop.
It's driving SWMBO mad but doesn't affect my PC as I'm wired. I thought it may just be coincidence but I keep losing connection on my HTC phone as well.
I've also noted that the portable radio, placed around 5ft from one of the Homeplugs, is suffering from interference.
My question is should the Homeplugs affect the radio and the wireless as described?
Forum Moderator and Customer
27-06-2012 10:29 PM
Quite why that was needed I have no idea but fingers crossed...
27-06-2012 11:23 PM
If so, that is likely the cause.
28-06-2012 12:05 AM
Since re-powering there hasn't been a problem.
28-06-2012 12:12 AM
I love my Devolo 500 units, great coverage.
They have impacted my DAB coverage though, but not enough that makes it useless. That said, the fact I have the homeplugs means I don't even need the DAB now due to content availability
