Home Wifi network
- Re: Home Wifi network
Home Wifi network
29-09-2015 4:16 PM
Got fibre installed last week
I use wifi full time as I like the freedom so looking into replacing the router that plus net supply with a duel band.
So what router do people suggest to go to the open reach fibre modem and possibly a wifi booster too.
Can I ask if I got a router with a built in modem can this be use in any BT socket in house without having use the opemreach modem?
Many thanks.
29-09-2015 4:35 PM
29-09-2015 4:42 PM
29-09-2015 5:37 PM
29-09-2015 5:45 PM
Why can my mate who with bt can have his bt hub in any socket of the house?
29-09-2015 6:10 PM
Quote from: https Install the service at any point within the premises - although the GEA-FTTC speed may be affected, you and/ or your customers may choose to use microfilters and install their device on any existing extension socket.
29-09-2015 6:22 PM
29-09-2015 6:27 PM
29-09-2015 6:29 PM
29-09-2015 8:37 PM
York.
29-09-2015 8:39 PM
So all of u say it need be in the master socket which goes the small plug for router?
What are power line extenders like?
29-09-2015 9:20 PM
Quote from: Mustrum Your mate has ADSL, you have fibre, they work differently, and fibre can only work off the main socket.
that's simply not true.
fibre can work off any socket providing the sockets are wired suitably.
29-09-2015 9:31 PM
29-09-2015 9:37 PM
as said, fibre works just the same as ADSL in terms of phone sockets.
if you have a a standard master socket without a separate filtered socket then fibre works the same as adsl - ie filters on the end of every socket and the combined fibre modem/router can be connected to any of the sockets.
if it's a new BT master socket with separate filtered socket then the modem/router can be connected to that, or an extension can be run from the pre-filtered socket where the modem/router can be connected to that.
with most ISPs now on the "self install" product, the former (rather than the latter) will become the default method of installation.
29-09-2015 9:41 PM
dick:quote
