Hijacked Browsers
valart
Hijacked Browsers
Many years ago when I first used broadband my browser was hijacked and it was costly at the time I had dialup then I used to buy a card with a password which allowed me a months broadband,I managed to get rid of the virus and I contacted BT and they put a block on these type of telephone numbers I just wondered if PN had anything in place and does this hijack browser still excist.
13 REPLIES 13
picbits
Re: Hijacked Browsers
I've not seen a computer with a fax modem built in for many years now - if you don't have one connected to your line, there is no way your computer can make the premium rate calls.
spraxyt
Aspiring Legend
Fixes: 75
As you say at that time you were using dial-up (narrowband) and the 'hi-jack' would have been to cause an expensive number to be called with your traffic monitored and potentially interfered with.
You are now using broadband which is an always-on service (with your phone usable alongside internet usage). So the same connection hi-jacking technique doesn't apply. Sadly that doesn't make exploits a thing of the past, and appropriate protection is still needed. In fact the higher speeds of current connections can make protection even more essential. These are firewalls, anti-virus and anti-malware.
Windows now comes with a built-in firewall, but there are both free and paid-for alternatives available on the Internet. There are also free and paid for anti-virus and anti-malware applications available. I hope you already have suitable protection.
A discussion of alternatives is beyond the scope of your original question - not my preference but Plusnet offer Plusnet Protect powered by McAfee - free or £2 per month depending on broadband product.
David
valart
I have Malawarebytes and Microsoft Security Essentals which are both free would I get better protectection if I paid for it
picbits
Those should cover you pretty adequately - you can pay more and maybe get slightly better detection rates but I've never had a problem with MSE / Malwarebytes personally.
spraxyt
Aspiring Legend
Fixes: 75
I use both of those on my laptop, Malwarebytes with Avast free anti-virus on my desktop and a different free security package on android devices.
Paying for the pro versions generally provides additional features, which might expand the scope of protection but not per se improve it,  but as will be apparent I don't currently choose those. None of the options (free or pro) absolve the user from taking care.
David
ReedRichards
Seasoned Pro
Fixes: 25
It was not your browser that was hijacked all those years ago, it was your internet connection.
The modern equivalent is a virus that redirects all your internet traffic via a proxy server.  The proxy can take you where it likes so you could enter www.bbc.co.uk and the proxy might take you to www.itv.co.uk. ; Or you enter the URL of your bank and the proxy takes you to a site that will mimic your bank and attempt to steal your password.  Since you could legitimately want to use a proxy server, it is quite difficult for security software to deal with this threat.  Even if the 'virus' is removed, the corrupt settings can remain.
gleneagles
Aspiring Legend
Fixes: 17
Am I correct in assuming that if you were using Linux this type of thing could not happen to you ?
We are born into history and history is born into us.
ejs
Aspiring Hero
Fixes: 25
No, it would be possible to trick you into installing a browser add-on or downloading and running something, that could mess with your web browser and other settings, even on Linux. It may be less likely to happen on Linux, but this could largely be due to far fewer people using Linux, so it is not really targeted as it's not worth the effort of the people creating the malware.
VileReynard
Fixes: 20
In Linux you would have to download a program and execute it on your machine.
You would need to take positive action to do this.
Never run a program from an untrusted source.  Cheesy
ejs
Aspiring Hero
Fixes: 25
Not if there were some flaw in e.g. your web browser or one of its plugin-ins that allowed "remote code execution". Or would you care to explain how Linux makes that impossible?
VileReynard
Fixes: 20
Since programs execute under user level permissions, the worst situation would (conceivably) corrupt your user files.
But you have backups.  Grin
You basically do not have any authority to cause corruption to any system files.
ejs
Aspiring Hero
Fixes: 25
Which is more important, a load of operating system and program files that you could re-install in a few minutes, or all your personal documents and settings, including the browser settings in the original question? And you could do all sorts of bad things just by running or changing things as the user could.
And you don't have to run everything with administrative priviledges in Windows either.
And of course there could be some flaw or misconfiguration (in any operating system) allowing a program to gain priviledges to change system files.
VileReynard
Fixes: 20
Quote from: ejs
But most people do.  Grin
