Help
mike360
Help
Hi all i have just opened services on windows 7 and i can see this does anyone know how to fix it. thanks
Re: Help
try show hide console tree, 3rd icon in
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
mike360
Re: Help
Not working but thanks.  Embarrassed
dick:quote
Re: Help
only other options I can see that make mine look the same is via view - customise / snap in at the bottom
mike360
Re: Help
yes done it via these cmds:
Run cmd As Administrator (Windows 7)  type regsvr32.exe jscript9.dll (press enter) type regsvr32.exe jscript.dll (press enter) both should be successful.
