Help with heatsink please
Fantasticfourum
Hi
I have descovered with the expertise of Oldjim that my core temp is getting high and i want to change my heatsink and fan for a bigger better one
The only problem is i am not sure what i should be looking for i know Amd and Intel will be different but not sure if most heatsinks will fit or what i should look for
Jim recommended the following
4. Remove the CPU cooler and clean the CPU and cooler mating faces with a proper cleaning solution so that you have two absolutely clean surfaces
5  Reseat the heat sink using Arctic Silver 5  in accordance with the instructions
I thought as i am going to this trouble i may as well replace heatsink and fan for a better one
My Specs are below so if i can be directed to the appropriate heatsink or type i would greatly appreciate it.
Gigabyte Technology Co., Ltd. GA-MA74GM-S2H
Enclosure Type: Desktop
2.93 gigahertz AMD Athlon 64 X2 Dual Core
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
3328 Megabytes Usable Installed Memory
Slot 'A0' has 2048 MB
Slot 'A1' has 2048 MB
Windows 7 Ultimate (build 7600)
Many Thanks
11 REPLIES 11
Fixes: 393
Re: Help with heatsink please
Your Motherboard is an AM2+/AM3 socket. so you need a cooler compatible with that type of socket.
Here's a selection of coolers http://www.aria.co.uk/Products/Components/Fans%2C+Heatsinks%2C+Coolers/CPU+Coolers/?x=12&p_order=pri... , check it for AM2/AM3 compatible ones.
I use this one on my dual core Athlon for example http://www.aria.co.uk/Products/Components/Fans%2C+Heatsinks%2C+Coolers/CPU+Coolers/Arctic+Cooling+Fr...
Fantasticfourum
Many thanks thats just the info i needed Regards Mike
Fantasticfourum
Hi MisterW
Thanks for your input but i was going to order the same one as you but when i went to their site
http://www.arctic-cooling.com/catalog/product_info.php?cPath=1_43&mID=133&language=en
they say this is only compatible for a single core so i am a bit unsure if this is the right one
Also it says fitted in seconds , will i not have to get the heat resistant compound and put that on before fitting ?
wacky17
Why dont you go with the Corsair H50 http://www.ebuyer.com/product/177411
Fixes: 393
from the website
Only compatible with Single CPU motherboards
It means a single physical CPU not a single core.
It comes with thermal paste pre-applied
Thermal Interface Material: Pre-applied MX-1 / MX-2 Paste
Edit: check there is sufficient room in your case ( especially if its a small or low-profile case ) because that cooler is quite large.
Fantasticfourum
Hi
Ok i will order that one as it seems the best around
Sorry my lack of knowledge is a big part of the problem
I thought as there were two cores there were two cpu's
need to learn a bit more about computers i think
Many Thanks for your help
Fixes: 393
They're good value and a pretty good cooler. My dual core Athlon sits at about 34 Deg with the fan spinning at 1000rpm and the great thing is, its QUIET!. Yes, there are better coolers around but they are much more expensive.
Fantasticfourum
Yes the other one recommended is nearly four times the price....Thanks
Fixes: 393
Even though the new heatsink will have thermal paste already applied, make sure you clean any old paste from the CPU before fixing the new heatsink.
Fantasticfourum
Will Do Many Thanks for all your help........
gadfly
The following cooler supports all of the current and most of the past Intel and AMD sockets, so if you change to an Intel motherboard you can use it.
Thermaltake Contac 29 review -
http://www.expertreviews.co.uk/gadgets/277033/thermaltake-contac-29
Supplier: http://www.specialtech.co.uk/spshop/customer/product.php?productid=10703&cat=515&page=1
