Help with Netgear WN1100 wireless Adapter
- Help with Netgear WN1100 wireless Adapter
Re: Help with Netgear WN1100 wireless Adapter
29-11-2011 3:12 PM
Thank you very much for very clear explanation of how DNS thing works. I think I understand !
Yes, you are correct. Any links seem to be slower in responding. So, I need to change the the DNS server addresses from 4.2.2.2 and 4.2.2.1. Do you think if I change to the OpenDNS, 208.67.220.220, (as suggested by purleigh) which appear to be faster in responding rather than using Plusnet ones you have suggested. In that case, what do I use an alternate DNS address as?
Will appreciate your comments.
Chandu.
29-11-2011 3:17 PM
and 8.8.8.8 (Google) as secondary
29-11-2011 3:22 PM
Thank you for providing the bar-chart of response times for various DNS servers. It is very informative and an eye-openner. You suggest using the OpenDNS (208.67.220.220), which is faster than the Google (8.8.4.4). May please ask what are the alternate Addresses for bothof them? As both of them are much, much faster than what I am currently set at and they are slow on link responses.
I will appreciate your feedback on the above. Thanks in advance.
Chandu.
29-11-2011 3:29 PM
Set Primary DNS to OpenDNS = 208.67.220.220 or 208.67.222.222
and secondary/alternate DNS to Google = 8.8.4.4 or 8.8.8.8
I tend to avoid the Plusnet DNS for three reasons -
1) Despite being theoretically closest and should be fastest, Plusnet DNS has ALWAYS been slower than OpenDNS, and usually slower than Google DNS.
2) In the past the Plusnet DNS has not exactly been reliable, whereas OpenDNS and Google are VERY reliable.
3) For various reasons, the Plusnet DNS has problems resolving commonly used URLs (particularly English school websites), where OpendDNS and Google work more of the time.
29-11-2011 3:29 PM
Quote from: Oldjim I use 212.159.13.50 (Plusnet) as primary
Thanks, Oldjim. This is all interesting, but mind boggling. I am learning fast.
Chandu.
29-11-2011 3:38 PM
@ Oldjim, Thanks. The Plusnet DNS server (212.159.13.50) - is it better than what purleigh has mentioned above about 212.159.6.9 ?
Chandu.
29-11-2011 3:41 PM
29-11-2011 3:50 PM
In my opinion YES they are.
OpenDNS is used by many establishments such as schools because of the superior address filtering, parental controls and anti-phishing capability you can choose to activate on your line - FOR FREE.
However there are a few conspiracy theorists on this forum who take the view that OpenDNS are up to no good - but have never shown any evidence.
Have a look - http://www.opendns.com/home-solutions/
Google DNS is probably like any other Google feature, in that it probably logs every lookup you do and uses that anonymous data to feed you related content at some point.
29-11-2011 3:53 PM
Quote from: purleigh All four Plusnet official DNSes - 212.159.13.49, 212.159.13.50, 212.159.6.9, 212.159.6.10 are all about the same
Noted and Thanks.
Chandu.
29-11-2011 4:38 PM
Quote from: purleigh In my opinion YES they are.
Thanks for the info. Much appreciated.
Chandu.
29-11-2011 5:03 PM
When doing the speed test earlier, my home DNS server was responding in typically 1.3ms and worst case about 18ms, using an old 533Mhz Pentium-3
29-11-2011 8:16 PM
Quote from: purleigh If you REALLY want good DNS performance and you happen to have any old PC laying around, you could build your own DNS server.
Sorry, don't have an old spare PC. The desktop which has had the issue is quite old with P3, but still used as a family workhorse.
By the way, what did you use to do the speed checks you had posted earlier. Is it a special software?
Chandu.
30-11-2011 10:43 AM
The speed test results are from http://www.speedtest.net/
30-11-2011 4:55 PM
Quote from: _Adam_Walker_ The speed test results are from http://www.speedtest.net/
Hello Adam. It is nice to hear from you again.
I believe, we were discussing the DNS Server Response speeds rather than the line speeds. Please do correct me if I have got it wrong.
Regards,
Chandu.
01-12-2011 12:59 PM
I though you were referring to the speedtest.net results in Purleigh's signature. If you're referring to the graph on Reply #29 I'm not sure, purleigh can probably tell us though.
