Help setting up Joomla
oldgustav
Can anyone please point me in the direction of helpful information to set up and install Joomla? I use a Mac and so far all I understand is that I need to install the Joomla installation files somewhere on my web space - possibly on the cgi serverHuh Thanks.
Word_Warrior
Re: Help setting up Joomla
There are loads of help threads on the forums just use the search engine. That said, yes you need cgi or to be precise unix, apache and a mysql server. I wouldn't use the plusnet ccgi setup now though as that is obsolete as far as Joomla is concerned (it does work but some stuff doesn't)  it is still php4 but fear not, ask to join the plesk trial (also on these forums) and upload and run Joomla there.
Check out the "advanced hosting" threads in the forums (you have to be logged in to see it) There's stuff there to help you upload and un tar in plesk. Don't be phased, it's a piece of cake to do.
Word_Warrior
This works for the Plesk platform
http://community.plus.net/forum/index.php/topic,69399.msg553486.html#msg553486
Don't forget that this thread needs you to login.
Andy
digitig
Quote from: Word
I've searched the forums and can't find anything telling me what plesk is or how to join the trial (although I've found a few messages asking for support on plesk). Could you tell me a little more, please, as I want to install Joomla! too.
Thanks.
Word_Warrior
Try this:-
http://portal.plus.net/wizard/?wizard_id=20 then click "hosting preview"
