Help please - I can't get X-lite to work
- Re: Help please - I can't get X-lite to work
03-11-2007 6:35 PM
Trying to activate x-lite on my computer. Followed the the set up instructions but I just get the message:
"Registration error: 479 - We don't accept private IP contacts."
Any ideas of how to overcome this?
Graham
PS. OK I solved it - used the NAT firewall settings
Graham
1 REPLY 1
04-11-2007 2:01 PM
Hi Graham,
Yes i was just going to say it's the NAT firewall settings just before you posted the update
