Help needed with laptop please!
FIXED- Subscribe to RSS Feed
- Re: Help needed with laptop please!
- « Previous
- 1
- 2
- Next »
15-10-2018 7:19 PM
Many thanks for all your help and suggestions
15-10-2018 8:51 PM
Ok, I follow that - just one question - if I carry out the changes will it affect internet access on other laptop, tv etc. Sorry for being pedantic but am a bit unsure of what I am doing (being crinkly).
Many thanks
15-10-2018 9:43 PM
You need to select each band in turn on your devices and use whichever works best.
16-10-2018 8:24 AM
@KI28 Great to hear you have a solution, could you mark @Baldrick1's response as a fix as it might help others in the future.
22-10-2018 9:31 AM
Just read post detailing Router change - as an 'old git' who is a bit unsure on making these changes do I change the wireless SSID box from PLUSNET-WXF8 to PLUSNET-WXF8-5Ghz (thats in addition to changing the 2.4GHz from YES to NO)
Many thanks and sorry for being a pedantic!
22-10-2018 11:05 AM - edited 22-10-2018 11:12 AM
Yes. If you then do a search on your device for available networks, providing the device is 5GHz capable, you will see both listed. Try each in turn and use the best.
- « Previous
- 1
- 2
- Next »
