Help needed with laptop please!
KI28
Re: Help needed with laptop please!
@Baldrick1 Thank you! I've done this tonight and it's solved the problem. We're now able to use WiFi on the laptop and I have one happy teenager!
Many thanks for all your help and suggestions
greystuff
Ok, I follow that - just one question - if I carry out the changes will it affect internet access on other laptop, tv etc.  Sorry for being pedantic but am a bit unsure of what I am doing (being crinkly).
Many thanks
Fixes: 419
You need to select each band in turn on your devices and use whichever works best.
@KI28 Great to hear you have a solution, could you mark @Baldrick1's response as a fix as it might help others in the future.
greystuff
Just read post detailing Router change - as an 'old git' who is a bit unsure on making these changes do I change the wireless SSID box from PLUSNET-WXF8 to PLUSNET-WXF8-5Ghz (thats in addition to changing the 2.4GHz from YES to NO)
Many thanks and sorry for being a pedantic!
Fixes: 419
Yes. If you then do a search on your device for available networks, providing the device is 5GHz capable, you will see both listed. Try each in turn and use the best.
