Help, just how do I get Linux to work?
- Help, just how do I get Linux to work?
Re: Help, just how do I get Linux to work?
28-02-2016 2:28 AM
If you had access to Linux, it would be easy to burn a bootable DVD.
28-02-2016 8:49 AM
I have no problems burning discs with windows.... indeed, I could not have had access to Linux, if I did..... ( unless I went down the "paid" O.S. route or borrowed it from someone else)..
doris barloff came here for help, not sarcastic comment
28-02-2016 10:17 AM
Quote from: Nibiru If you used a USB flash drive (instead of the read only DVD), then you should be able to install the necessary packages (i.e. Chrome and possibly some codecs) to the USB flash drive, so that they are available to use every time you boot your PC.
The other advantage of using a writable USB flash drive is that your settings and other history will be remembered between sessions, for example WiFi SSID and password, browsing history, etc.
28-02-2016 10:41 AM
Burn bootable iso: will put a copy of dos or a M$ bootable file on the disk for you, then you add your additional files.
Burn disk: will just put what files you select on a disk
the one you need is BURN IMAGE. But this may only burn its own images, I am not familiar with the program, if it will burn ISO's then select the iso file from the image menu, you don't need to extract or do anything to the image file other that burn it.
Also try burning at a low speed. Some writers have problems with bootable iso's at high write speed so try 4X.
28-02-2016 11:36 AM
As the Hairy one has said you need to do an ISO write, which I know you have done so this is raising my suspicions as to the integrity of your hardware, more so when ISO Recorder failed for you.
You need to get your hands on a bootable disk and actually find out if the machine(s) will work. If you can't get a disk from anyone then I'd suggest that you go to a PC World and tell them you have a problem booting a disk can they try it please. If it boots then it's back to the drawing board you can walk away saying 'Thanks, must be me'. If it doesn't boot you can still walk away saying 'Oh well, it's a bit old and not worth the repair bill'.
At least this way you will know if you're banging your head against a wall.
28-02-2016 11:49 AM
I'm frustrated but not that worried. Just ordered a Kindle fire hd from Amazon for £40. I've already spent £15 on discs and a pack of beers ( I put them down as justifiable anaesthesia , so they get charged to this job ), so the tablet may work out cheaper and gives me time to play with it. So no rush to sort this out.
@ Hairy MC... I have tried the 'Boot ISO' option, to no avail.
I will try the USB stick next, then architectural rearrangement ( with my friend Mr Lumphammer).
Seriously though, it will be a case of copying all photos then doing a reformat (can you do that on a laptop). That's after I try to do a factory restore , though that only gives me vista again! Though if I keep it disconnected from internet it won't start the updates etc, and hopefully the dvd will burn and load correctly!
28-02-2016 11:56 AM
Quote from: doris Please don't fall out over this.
Where did that come from?
28-02-2016 11:57 AM
I have tried burning on both laptops and opening dvds on both laptops, using all combinations, which leads me to conclude that either I'm the unluckiest man alive and both machines are faulty or I'm doing something (or several something's) wrong.
I won a tenner on the lottery once so I think I must be doing something(s) wrong.
28-02-2016 12:01 PM
Quote from: Mook
Posts 60 + 61. Not really arguing, but don't want it to escalate.
I really appreciate the help and advice and don't want people to fall out over it.
28-02-2016 12:14 PM
Have you considered removing the existing hard drive (storing for safe keeping), then fitting a cheap replacement (from eBay) ?
That way you can play all you want with the new drive without risk to the contents of the existing drive, and if the worst comes to the worst you simply refit the original drive, and you would be no worse off than when you started.
First you need to identify what your existing hard drive is, to check whether it's PATA or SATA interface, and whether 1.8" or 2.5" size.
Assuming your laptop uses the most common standard SATA 2.5" drive, I would recommend (for what you are doing), to look at -
Western Digital 2.5" Black SATA2 7200rpm 160GB laptop drive - at about £15 on eBay.
or
Kingston 2.5" V300 60GB or 120GB SSD - at about £20 to £25 on eBay.
Unlike Windows, Linux doesn't need a large hard drive.
As a separate question, how much RAM does this laptop have ?
28-02-2016 12:34 PM
28-02-2016 12:39 PM
28-02-2016 12:49 PM
28-02-2016 1:09 PM
28-02-2016 2:59 PM
If so that is the problem, you need to raw write the .iso file directly to the DVD/CD/USB; so opening up to look inside and you loose that the .iso is a bootable media.
Just a though, if you try again.
