Help, just how do I get Linux to work?
- Help, just how do I get Linux to work?
20-02-2016 5:10 PM
I install dvd and start up laptop, but it doesn't auto run. I go into BIOS, on start up, and the only option available is to boot from windows. Autorun is enabled. I open up the dvd player and even though the disc shows, there is no'run' option.
So it appears I have what I think is Linux mint on disc, I can't get it to run, though I can access it down to file folders.
It's running vista home basic at the moment.
Can anyone tell me where I'm going wrong please?
Thanks in advance. Attached picture is the files on disc.
Re: Help, just how do I get Linux to work?
20-02-2016 6:23 PM
20-02-2016 7:44 PM
Find your Linux Mint downloaded .iso file in your download folder
Insert clean DVD disc
Right click on it... and it should give you the " Burn Disc Image" dialogue. ( at the top of the drop down )
Once it has been "Burnt" ... shut down the laptop... then re-boot.... if you have the DVD player as 1st boot option, you should get the Linux mint as previously mentioned in your other thread.
Good luck
20-02-2016 8:26 PM
20-02-2016 9:18 PM
Running vista home basic.
20-02-2016 10:11 PM
If not, when booted up... ask google.... How do I change the boot order on my XXXXXXXXXXX machine running Windows Vista... maybe something will come up...
21-02-2016 12:46 AM
21-02-2016 9:02 AM
21-02-2016 11:32 AM
Quote from: doris I downloaded Linux mint, [...] I want to run of dvd and not install it. It's only to provide access to streaming Netflix (see other post for reasons, etc)
I suspect you're going to be disappointed; the downside of running Linux from DVD is that you can't update or add to the software packages you've burned to disk.
AFAIK the default browser on Mint is Firefox which doesn't, on Linux, have the Digital Rights/Restrictions Management support demanded by Netflix.
I believe you'd need Google's Chrome browser (or Chromium with Google's widevine plugin) to stream Netflix on Linux.
21-02-2016 11:44 AM
If you used a USB flash drive (instead of the read only DVD), then you should be able to install the necessary packages (i.e. Chrome and possibly some codecs) to the USB flash drive, so that they are available to use every time you boot your PC.
The other advantage of using a writable USB flash drive is that your settings and other history will be remembered between sessions, for example WiFi SSID and password, browsing history, etc.
21-02-2016 4:21 PM
21-02-2016 4:22 PM
21-02-2016 5:51 PM
Quote from: Mook Is Chrome OS an option for you?
Strictly speaking, ChromeOS is only available on Chromebooks / Chromeboxes / Chromebits.
Quote http://getchrome.eu/download.php
Cr OS Linux is an openSUSE derivative; has Chromium as default browser - no idea if it has the required DRM plugin Netflix demands.
21-02-2016 8:05 PM
http://www.ebay.co.uk/itm/Linux-Mint-15-Olivia-Operating-System-OS-Desktop-laptop-PC-Photos-Music-/3...
21-02-2016 9:24 PM
This comment has nothing to do with the other thread regarding the compromised ISO it is based solely on the "what's in it for me" and my innate distrust of such things.
