Help! What has gone wrong? Divs and tables shifting to show incorrectly
nicolel
Hello everybody! I'm stuck again, what would i do without you good people?  Wink
I have been making a new layout for my webpage using fixed columns, with 1 sidebar with a menu in, the other sidebar with some more information in.
The main section I have made using AP Divs with a border to put products in, with a table inside it to keep everything neat. Everything was perfect, then I did something... Havent a clue what, but now all my divs are showing too small when previewed, so the text and images are leaking out and running over each other!
I'm using dreamweaver CS3.
It has also done it with all the pages I have made previously. One of the pages in question is here http://www.concept-data.com/X1024x768.html
PS - The navigation menu is only a placeholder JPG.
Please can someone help me un-screwup? Thanks so much, your all great!
Nicole
Tyreal74
Re: Help! What has gone wrong? Divs and tables shifting to show incorrectly
Ive just tried it in IE and Firefox and it renders fine...even when altering the page width.
Fixes: 356
Looks fine in Firefox and IE8 here too
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
nicolel
oh, thats even weirder! This one is showing incorrectly also -  http://www.concept-data.com/Xcoloursleafletholders.html
I have attached the image of what it *should* look like so you can compare. It seems to have an issue with the bottom of the page with this one.
Thanks again guys,
Nicole
Denzil
Both pages look fine to me. Nicely laid out, I think. I wouldn't rely on the preview in web creation software, as they are often a bit limited with anything other than pure html. It is more reliable to see it in a browser.
Fixes: 356
Quote from: nicolel
Looks fine too...
Quote from: Denzil
Agreed..
To the OP, I've found that Dreamweaver will render some material differently if you change the HTML header, have you done this?
nicolel
No I haven't changed the HTML header, that might be an idea. Can you give me a bit more detail please?
Thanks for all your replies!
Nicole
Tyreal74
All my html documents start with
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
and that goes for anysites i have built or building...
pierre_pierre
I have a similar problem with a Web site my Daughter has just got set up by a "Designer", it renders OK in Firefox, Opera and IE7 but not IE6
http://www.themartialartscentre.com
Tyreal74
no one caters for ie6 very much anymore...unforetunately i have to
pierre_pierre
try this Web Compatability tester  http://browsershots.org
