Help!! Unable to copy any files to disc.
- Help!! Unable to copy any files to disc.
- « Previous
- 1
- 2
- Next »
Re: Help!! Unable to copy any files to disc.
04-11-2010 8:15 PM
usb external burners are so cheap anyway
just look in amazon com
04-11-2010 8:27 PM
Success!! Just had time to download "ifrarecorder" as Jim suggested and had no trouble burning a whole file of photos to CD. So it must be OK, just the software needed, must have got lost somewhere !!
Thanks so much for all the help to a " noddy " .
Thank goodness for all the people who offer help on this Forum !!
Nick
Nick
04-11-2010 8:31 PM
If that software worked, then maybe, just maybe, you need to do the "disconnect" bit and re-istall the driver when the computer "recognises" the dvd on re-fitting and re-booting.
Glad you got it working though....
05-11-2010 5:04 PM
Thanks Shutter for the offer of the guide for Irfanview, I have sent you an email address. Hope you got the message !! I might get adventurous and try to do a bit more burning to disc. Probably don't need to bother about the unplug bit, if it works with Irfanview and Infrarecorder !! They seem better programmes than I was using before anyway.
Cheers Nick
Cheers Nick
05-11-2010 5:43 PM
Yep !... and sent you the guide....
- « Previous
- 1
- 2
- Next »
