Help Network Building
- Help Network Building
08-05-2019 7:21 PM
Server rack cabinet 19 inch 6U 600x450x370mm wallmount SOHORack by RackMatic https://www.amazon.co.uk/dp/B01MXHFI6G/ref=cm_sw_r_cp_api_i_01X0CbH4M6ACF
UBIQUITI Networks UniFi Cloud Key Controller https://www.amazon.co.uk/dp/B017T2QB22/ref=cm_sw_r_cp_api_i_n2X0CbBH9N7PP
UniFi Switch 24 Non-PoE https://www.amazon.co.uk/dp/B00QUEOOR0/ref=cm_sw_r_cp_api_i_z2X0CbD7K11D8
UBIQUITI USG-PRO-4 UniFi Security Enterprise Gateway Router with Gigabit Ethernet https://www.amazon.co.uk/dp/B01A9HFTYA/ref=cm_sw_r_cp_api_i_R2X0CbRTMX0ZR
Ubiquiti Networks UAP-AC-LITE WLAN Access Point https://www.amazon.co.uk/dp/B016K4GQVG/ref=cm_sw_r_cp_api_i_52X0CbP2PNAS1
Re: Help Network Building
08-05-2019 7:46 PM
Moderators Note
This topic has been moved from Fibre to Tech Help
08-05-2019 8:39 PM
If you are spending that kind of money then you should hire an professional expert.
08-05-2019 8:56 PM
09-05-2019 2:30 PM - edited 09-05-2019 2:34 PM
This may be helpful:
https://help.ubnt.com/hc/en-us/articles/219051528-UniFi-Setting-Up-UniFi-for-Beginners
Dave
ps There are a lot of other sites that show how to setup. I just did a search for "how to set up UBIQUITI gateway router"
09-05-2019 4:18 PM
A small USG3 with an 8 port PoE switch and AC-Lite should be plenty for a small flat.
I work day to day deploying UniFi into multiple distribution environments and know the product(s) very well and am happy to answer any questions you have.
a good place to start is on YouTube and watch a guy called Chris who uses the channel name Crosstalk Solutions. Very informative.
09-05-2019 4:26 PM
