Help! I need a ADSL Router that meets the following spec...
- Help! I need a ADSL Router that meets the followin...
04-12-2009 10:05 AM
Integral PSU - no plug top or inline transformer
No integral WiFi
and finally not Cisco!
Anyone out there got any recommendations or suggestions?
Re: Help! I need a ADSL Router that meets the following spec...
10-12-2009 12:29 PM
10-12-2009 12:57 PM
10-12-2009 1:32 PM
The extra fan cooling would be handy, and I can probably re-use the PSU - just need to make a new front panel and move the LEDs to it.
Hmmm....
Xmas project?
10-12-2009 1:41 PM
These are needed for a "industrial" remote installation, I'm only quoting what the client wants!
Metal cased to assist with heat disipation.
Integral transformer to allow direct connection to UPS
No Wifi - Purely a cabled installation, but I guess we could purswade them to simply have this disabled.
Not Cisco - clients policy!
@ James_G - Yep we've had similar thoughts, but then the issues of Warranty and dare I say CE Complience are rasied!
10-12-2009 2:09 PM
10-12-2009 2:51 PM
It does use a power brick with an integral 13A plug though but you could do what we do - buy a suitable mains transformer (2820 needs 15V) with an IEC mains inlet and the appropriate output voltage and connector to replace the supplied power supply and fit it to the rack kit (you may have to drill holes and use tie wraps to mount the transformer) e.g. this sort of thing from Maplin.
10-12-2009 7:52 PM
10-12-2009 8:09 PM
@Username,We've used quite a few of their switches in systems we've supplied to clients. Mainly for the same reasons as you, integral PSU and rackmount. This is the distributor we use http://www.micro-p.com/products//NETWORKING/NETWORK-ROUTERS/ADSL-ROUTER/ALLIED/ALLIED-Routers-ADSL-R...
I can't believe the price is £575, I've got a MicroP trade catalogue, if I remember when I get into the office tomorrow I'll look for the price and let you know!
11-12-2009 9:33 AM
Ok , well the SRP is £654!!! , the catalogue doesn't give a trade price for the AR440 ( obviously not a high volume unit ) but based on the SRP to Trade price ratio for other items it's likely to be about £370.
Hope that helps.
11-12-2009 9:58 AM
