Help I lost me clock
Teds31
Hi I have lost my clock on the RH side of the task bar, I have seen a repair for this somewhere but I cant find it , can any one help please. I am useing windows 7, (64 bit), TED
Steve
Seasoned Pro
Re: Help I lost me clock
Fixes: 62
right click on desktop - select gadgets and there it is - just drag it to the desktop
I shouldn't quick scan posts before replying  Embarrassed
Fixes: 10
Right click the task bar and select properties. Click the Customize button for the notification area.
At the bottom of the "Select which icons and notifications appear on the taskbar" page click the Turn system icons on or off link.
You can turn the clock on and off in there.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Teds31
As usual thanks every body Jelv you were bang on. So simple yet Icoudn't see it  Ted.
