Help Experts needed
- Re: Help Experts needed
Help Experts needed
30-10-2009 8:00 PM
I have decided to buy a new computer and have been looking at the available options but i realize i need more expert help as much of what is out there is pretty mind blowing and confusing. However i have found a tower (dont need monitor etc) that seems quite good for the money but i am not sure and so turn to the experts.
It is on Ebay (which may not be a good start) but it can be found at http://cgi.ebay.co.uk/INTEL-QUAD-CORE-GAMING-DESKTOP-COMPUTER-PC-GEFORCE-9600_W0QQitemZ370210602362Q...; or if that doesnt work the item number is 370210602362. If any one can take the trouble to look i would greatly appreciate any opinions. Many Thanks Mike
30-10-2009 8:11 PM
Looking at the machine you propose, I guess that you are into serious gaming?
Maurice
30-10-2009 8:34 PM
30-10-2009 8:48 PM
31-10-2009 10:44 AM
As for fleabay, I can't comment on that, after 3 bad experiences with dealers on there I don't really bother with the place now. If you're buying brand new, try to avoid the big box shifters if possible, stick to the little shop on the High Street. You'll get a much more impartial service from them than you would from a shirt and tie who's just after the commission for shifting units. And you'll know what's in it because you chose it and you won't get a 3 year warranty that costs as much as the tower itself. Most printed box components come with a standard 3 year warranty anyway, if not more.
31-10-2009 11:54 AM
31-10-2009 12:33 PM
31-10-2009 12:43 PM
31-10-2009 2:19 PM
31-10-2009 6:17 PM
I've used them for about 5 years both for a small charity and personal PC's and Monitors.
Good range of systems Intel & AMD and lots of scope to define your needs.
Maurice
31-10-2009 6:50 PM
31-10-2009 7:24 PM
01-11-2009 9:35 AM
01-11-2009 2:32 PM
I got a computer from the site MauriceC mentions in his post.
15 months later windows failed to load so I contacted them as everything is covered by a 2 year warranty. They arranged collection of the computer the next day (Friday) and it was back with me the following wednesday..... faulty memory chip. Very impressed with the service and the fact you could "build your computer on the web" and a small box kept track of what the cost was based on your selection.
I Have had some good bargains on e-bay but have also had problems so its a gamble and in many cases you are unable to return goods purchased on e-bay !
Re:Help Experts needed
02-11-2009 1:00 PM
Hope that helps,
