Help Assistant
- Help Assistant
Help Assistant
02-02-2014 3:21 PM
I want to ask another question on Help Assistant but as I have four open questions I cant do that. How do I close a question or two because there is no window/box to do this
Al
Al
3 REPLIES 3
Re: Help Assistant
02-02-2014 5:13 PM
If you go to the question there should be an option to close it - UNLESS they were opened by staff then you can't
Re: Help Assistant
03-02-2014 3:59 PM
So do I have to phone the staff or can I email them and ask them to remove them?
Al
Al
Re: Help Assistant
03-02-2014 4:32 PM
Hi Al,
You should now be able to raise a further question now?
