Headset?
suesykes
Headset?
I have a trust headset with microphone... Can I use it to make internet calls by using software to dial....
Does it cost anything to call this way and can I call land lines?
Re: Headset?
Yes you can use it to make VoIP calls and in a lot of situations this is free (skype for example) and yes you can use it to call land lines though this will not be free and will almost certainly require a subscription. There are other services available but this is also a service we offer - please see this page for details.
Hope that helps,
suesykes
Re: Headset?
Thank you.
