Headphone repair help
- Headphone repair help
21-06-2014 10:51 AM
I have a light magnifier which should just about do me i hope.
Re: Headphone repair help
21-06-2014 11:41 AM
Make sure you get some liquid flux (good for SMT stuff) and fine desoldering braid and/or solder sucker !
Soldering fine pitch components often results in solder bridges which can be a pain to get off without the flux / braid.
I actually use a 3-4mm bit and drag solder SMT devices but that takes a fair bit of practice.
21-06-2014 11:50 AM
21-06-2014 12:26 PM
21-06-2014 7:30 PM
21-06-2014 9:24 PM
I have a range of irons from a cheap £10 100W brute to a top end Metcal which is a real eye opener if you've never used one before - almost instant heat and despite "only" being 50w it will keep up with a lot of the larger irons with ease. It effectively uses an induction heating technique which keeps the tip at a constant temperature and I've soldered some pretty heavy duty stuff with it.
I think I have around 10 irons all together including my first Antec one from when I was 14 years old - that iron is now 28 years old
22-06-2014 4:34 PM
22-06-2014 5:08 PM
22-06-2014 8:48 PM
Any idea on what solder to go for, I see a lot of opinions on types of solder, my thoughts are to get 0.3mm or 0.5mm 63/37 not sure on what make though.
22-06-2014 9:51 PM
I use the 0.7mm 60/40 solder from Rapid Electronics for most SMT stuff I do (I think that is what I use anyway - seems the smallest they do). The bigger stuff I use for cables etc.
Go for the thinnest stuff you can get - makes it a little easier for the fine tracks.
22-06-2014 10:19 PM
http://www.rapidonline.com/FFSearchResults.aspx?query=0.3mm%20solder&filterSearchScope=1
08-07-2014 1:50 PM
