Headless_Linux_Debian
- Re: Headless_Linux_Debian
21-05-2017 4:06 PM - edited 21-05-2017 4:07 PM
I'm following this one... https://www.howtoforge.com/tutorial/install-arch-linux-on-virtualbox/
Live medium I have
21-05-2017 4:15 PM - edited 21-05-2017 4:28 PM
Can I respectfully suggest that you follow this one, diverting (via tabs) when you need to.
Edit: For what it's worth, with the obvious exception of the Pi's all of my Arch Linux machines are VMs running under vmWare ESXi v5.
22-05-2017 11:37 AM
I see what you mean about that 1
I'm Warming to it, it's clean and fast
22-05-2017 5:50 PM
First Bad mark...
iftop: error while loading shared libraries: libncursesw.so.6: cannot open shared object file: No such file or directory
22-05-2017 6:33 PM
# pkgfile libncursesw.so.6 core/ncurses
Looks like you need to install ncurses.
22-05-2017 6:54 PM - edited 22-05-2017 6:54 PM
I'm just looking at it now, it works fine on my VM, but not the pi. Just doing a -Syu atm then I'll look again.
Ubuntu server is behaving so far with everything installed as expected, they make that easy don't they
22-05-2017 6:56 PM
Oh lord...
error: failed to commit transaction (conflicting files)
ca-certificates-utils: /etc/ssl/certs/ca-certificates.crt exists in filesystem
Errors occurred, no packages were upgraded.
synchronizing filesystem...
22-05-2017 7:02 PM
Did I break something ?
pacman -S bind-tools
dig google.co.uk
dig: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
22-05-2017 7:10 PM
everything works on the VM, just not the pi... hmmm hey-ho
22-05-2017 7:22 PM
oops..
@TheRoadCrew sorry, you did mention...
# pacman -Syuw # download packages
# rm /etc/ssl/certs/ca-certificates.crt # remove conflicting file
# pacman -Su # perform upgrade
22-05-2017 8:20 PM
And now it's all broken (read only)
22-05-2017 9:47 PM
Congratulations! I've never managed that
If that's the Pi, does this help?
22-05-2017 9:58 PM
Cheers
Yeah it's the pi.
I've re-installed it again, got all the programs working after the update but I've not restarted it yet!
Fingers crossed... thanks for the link.
22-05-2017 10:14 PM
happened again
nano /boot/cmdline.txt
rw rootwait
does indeed fix the problem, how bonkers!
23-05-2017 10:56 AM
Just adding this link, I've been having a few problems with the sorting out a static ip but all good now.
Which do you guys find the best, netctl or systemd ? I've had more luck with systemd so far.
