Hard drive
morgan2476
Hard drive
I have just made a mess of my mbr when i was uninstalling a linux partition.  What I now want to do is delete all the partitions and format my drive so it is as it were new.  Could someone give me a proceedure for this. I am using xp.  Thanks
10 REPLIES 10
Fixes: 1,483
Re: Hard drive
You can do this as part of the windows xp install when choosing where to install it to.
Gives you the option to delete partitions.
If it's a dual boot box you can use the repair console and try running fixmbr to sort it out.
ReedRichards
Seasoned Pro
Fixes: 25
Re: Hard drive
If you have the drive connected as a secondary drive on your Windows computer, right click (My) Computer and select Manage, then click Disk Management.  You should see your drive listed.  Right click it and select Format.  Make sure you select the correct drive!  AFAIK this works in all (recent) versions of Windows
Santiago
Re: Hard drive
Assuming dual boot, uninstalling the linux has wiped the MBR. You don't need to format the drive just reinstate the MBR
Here is a simple guide to reinstate your MBR in XP http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
I hope this helps
VileReynard
Fixes: 20
Re: Hard drive
Having said that - why/how would you uninstall Linux?
If it was me, I would just delete the partition and/or remove the appropriate filesystems.
Santiago
Re: Hard drive
When I started with Linux i did quite a few installs and uninstalls while I was playing around. It's part of the learning curve I guess.
If you delete the linux partition you will still end up messing up the XP mbr, trust me I did it myself, several times
Smiley
morgan2476
Re: Hard drive
Thanks for all who replied.  It was when i worked with the mbr that things went pear-shaped.  Eventualy i will only use Linux.  Thanks
VileReynard
Fixes: 20
Re: Hard drive
When I first started with Linux, I found it convenient to install a second disk that is totally for Linux.
Just change your BIOS settings to boot from the appropriate disk.
This is quite useful as it meant I could look at old Windows documents etc (all Windows systems are accessible from Linux, but not vice versa).
Totally secure MBR too! Smiley
Ben_Brown
Re: Hard drive
When I started playing with Linux I installed LILO on a floppy. Then if I wanted to use Linux I'd boot with the floppy in, and pop it out if I wanted Windows. Unfortunately most boxes don't have floppies anymore, so it's a bit more difficult.
David_W
Re: Hard drive
I've always had trouble with Linux and my hard drives for some reason, its terrible now because I have 1 ATA and 3 SATA and use SATA as primary but Linux wants to install onto the MBR of the ATA.  Mind you, a few years ago I stuck on Linux and used DOS to fire up loadlin (I think it was anyhow) and that booted me into Linux, but that was a long time ago and I've totally forgotten how to, or even why I had to.
KenA
Re: Hard drive
I use the System Rescue CD to help manage these sorts of things.  It's a linux image with a load of tools for disk management, including disk backup and restore.  It's downloadable free at http://www.sysresccd.org/, and help there too.
