Hard drive
- Re: Hard drive
Hard drive
23-07-2009 12:18 AM
Re: Hard drive
23-07-2009 5:54 AM
Gives you the option to delete partitions.
If it's a dual boot box you can use the repair console and try running fixmbr to sort it out.
Re: Hard drive
23-07-2009 2:56 PM
Re: Hard drive
23-07-2009 3:12 PM
Here is a simple guide to reinstate your MBR in XP http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
I hope this helps
Re: Hard drive
23-07-2009 5:28 PM
If it was me, I would just delete the partition and/or remove the appropriate filesystems.
Re: Hard drive
23-07-2009 5:54 PM
If you delete the linux partition you will still end up messing up the XP mbr, trust me I did it myself, several times
Re: Hard drive
23-07-2009 6:48 PM
Re: Hard drive
23-07-2009 7:01 PM
Just change your BIOS settings to boot from the appropriate disk.
This is quite useful as it meant I could look at old Windows documents etc (all Windows systems are accessible from Linux, but not vice versa).
Totally secure MBR too!
Re: Hard drive
27-07-2009 10:46 AM
Re: Hard drive
06-08-2009 12:05 AM
Re: Hard drive
09-08-2009 9:33 PM
