Hard drive icon
morgan2476
Hard drive icon
one of my hard drive has now changed its icon.  instead of the usual icon it is now a white icon with windows in it.  Anybody got any ideas how to get back the usual icon.  I can still access the drive OK
minkey
Re: Hard drive icon
This website tells you how to change your drive icons, so maybe you can use it to change it back to the default again.
http://www.virtualplastic.net/html/icn_drv.html
Hope this helps
Jeff
minkey
Re: Hard drive icon
And another thing you can do is in: Tools, Folder Options, File Types, Advanced, you can change the icon from there.
Jeff
morgan2476
Re: Hard drive icon
i am still not sure what to do.  Also, what is happening now when i double click any drive icon i do not open the drive but i get search result box.  this is quite frustrating.
