Hacking a SKY netgear router
- Hacking a SKY netgear router
20-11-2007 12:30 PM
basically the netgears work better withj vista than the belkin i have so i want a spangly netgear
edit: wrong forum - move plx
Re: Hacking a SKY netgear router
20-11-2007 1:03 PM
Or at least, thats what I did to mine..
Username and P/W for the router are most likely:
U: admin
P: sky
If you need any help, just gimmie a shout!
20-11-2007 1:11 PM
20-11-2007 1:15 PM
If they do, then you can try forcing a firmware onto the box. Off the top of my head it is a DG834G, or an DG834GT but I cant remember which.
Let me have a quick check of a box and I will try and link the firmware to remove the horrible Sky Lock in
20-11-2007 1:33 PM
and i think its the GTB not GT
hence why i was trying to flash it
20-11-2007 1:44 PM
20-11-2007 1:46 PM
20-11-2007 2:25 PM
20-11-2007 3:45 PM
20-11-2007 5:32 PM
20-11-2007 6:12 PM
The router connected to the internet straight away, and I didn't have to enter anything into it at all, so I assume they pre-configure them with the details.
As it worked, I just left it alone .. but I wonder if it was locked, or I just missed where the ADSL settings should be.
20-11-2007 6:43 PM
20-11-2007 8:57 PM
Quote from: Pcoventry just use the recovery tool ( google it) and then reflash it - takes about 5 minutes
The link in my post further up has all the details - including a link to the recovery tool.
Here's the link again anyway
SkyUser Forum » Flashing your router firmware
20-11-2007 11:29 PM
I wasn't too bothered whether it worked or not as i picked it up for nothing and only tried it to see if it could be done but it worked without problem and is now usable with any ISP
