HUB2 and USB port?
ora8i
HUB2 and USB port?
Morning All.
I've just setup HUB2 without difficulty  but I find myself looking ar the USB port and wondering what I can use it for.
I have a NAS connected so I don't really need extra storage but I do have a number of spare drives mainly in the "Tech Graveyard" so it's tempting to plug them in even though they would be horribly slow and the effort pointless.
Is there a better use for that USB port?   Why ont USB3?
ATB   ora
4 REPLIES 4
Fixes: 480
Re: HUB2 and USB port?
@ora8i
Not only is it USB2, it also uses the SMB1 protocol.
It’s probably best just left doing nothing.
bobpullen
Fixes: 331
Not bad for powering a USB-powered switch if you need more ethernet ports.
Alex
Fixes: 13
I think it is disabled by default, but I could be wrong.
As said, you may as well use it as a power source. USB switch as Bob says, or it may charge your mobile if you have a USB cable for it.
ora8i
I'll leave it alone Smiley
thanks.  Ora
