HTC Wildfire
- HTC Wildfire
HTC Wildfire
01-02-2011 8:19 PM
Re: HTC Wildfire
02-02-2011 11:32 AM
Hope that helps,
Re: HTC Wildfire
03-02-2011 9:10 AM
Bob
Re: HTC Wildfire
04-02-2011 10:33 AM
the laptop does not connect wireless i have to power down the router then power up to get a connection (works ok when connected with the ethernet cable)
We have 4 different moblie phone non of these can connect to my wireless connection
Security mode: WPA-PSK
WPA-PSK Encryption: TKIP+AES
WPA-PSK Version: WPA+WPA2
Re: HTC Wildfire
04-02-2011 10:40 AM
Bob
Re: HTC Wildfire
04-02-2011 10:54 AM
Have a look at the library article here: http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
You'll need a windows PC, the flashing utility (top one in the list of downloads) and the latest firmware (8.2.7.8 - the bottom one in the list of downloads).
Then simply follow the guide to upgrade the firmware - that should sort it for you.
Hope that helps,
Re: HTC Wildfire
04-02-2011 11:33 AM
Undecided as to do the fimware upgrade, if you take time to look at what other people on this forum have said about doing the upgrade you will understand what i mean, soooo many complaints about this router supplied by plusnet, why do they not get there act together and supply a decent router!!!!
Re: HTC Wildfire
04-02-2011 12:26 PM
To be honest the majority of posts I've read from people doing the upgrade state that it's solved their problem?
The fault is with the firmware that was being shipped rather than the hardware, however that batch has all gone now and those we're sending currently (and have been for some weeks now) are already using the latest version. Sorry you ended up with the fault, but you should find that the flashing goes without incident and if it doesn't work then I'm sure we can sort a replacement out for you.
Re: HTC Wildfire
04-02-2011 1:47 PM
Well i have just upgraded my firmware to the lastest 8.2.7.8 and guess what it seems to be working ok on wireless ;D, will let you know how i get on with my mobile connection later
Re: HTC Wildfire
04-02-2011 1:55 PM
Re: HTC Wildfire
04-02-2011 2:02 PM
Re: HTC Wildfire
04-02-2011 2:19 PM
Re: HTC Wildfire
04-02-2011 3:22 PM
If that is the case I'd expect it to be working, unless the encryption (WPA, WPA2 etc) is different on the phone than it is in the router?
Re: HTC Wildfire
04-02-2011 3:38 PM
Re: HTC Wildfire
04-02-2011 3:46 PM
Wireless connection just failed on my laptop, had to connect with the ethernet cable again >:(, so it looks like the new firmware did not solve anything
